1999 V70 with Check Engine Light On
So, Ive done some searches for the codes, but can't find any specifics.
My check engine light is on, so I ran the codes.
P0420
P0562
P1081
P1053 which is listed twice.
Any ideas?
Also, On the dual air controls, the one on the driver side is locked on cold so I cant adjust the temperature. Anything that would cause this?
Oh, and does anyone know where to get cheap replacement parts?
I need a CV Joint
Center Console Lid
Stock Radio
And some parts for the back door, as the connector is missing so I cant open it.
-Calle
P0420
P0562
P1081
Any ideas?
I need a CV Joint
Center Console Lid
Stock Radio
-Calle
Hello, Did you try Alldata[dot]com? Codes are general. You might have to search code-by-code on sites like these (Brickboard, Matthew's, even the V70R site). You'll find posts on each specific code in all likelyhood. You're not limited to the V70 sections either. Regarding your parts needs: Aside from junk/salvage/recycling yards you can try independant Volvo mechanics. They frequently have strippers "out back". Any CV joint problem is economically fixed part-and-parcel with an axle change out. What's wrong with your radio/CD/cassette? These radios have anti-theft codes which a dealer can look up, but the doner car's VIN is necessary. Even with the correct code, I don't know if one of these can migrate to a new car. I would guess that they could. Good luck. Kira
Viking70
Dec 24, 2009 04:06 PM
S70driver
Mar 28, 2009 02:18 PM
ErnstlS90
Oct 23, 2008 08:37 AM
