1999 V70 Wagon...Brake light bulb
Hi...
Just purchased a 1999 V70 Wagon, and the rear upper (above the rear window) brake light is out. I do not have the manual and can't seem to find out how to remove the panel to replace the bulb. I'm not keen on forcing the panel as I'm afraid I'm doing it wrong.
Thanks
Vulva
Thanks
Vulva
hi,dont worry. raise tailgate and to left of centre,you will see a small recess with two srews. undo these then
gently remove lower trim, pull apart as you move your hand along,plastic pop in/outs. from here you will be able to access top panel for window breaklight bulb. by the way. were can i get a parts catalouge for my wifes vulva ?
Hey Fivespeed...
Thanks again for your post. I'm going to try to take the bulbs out today. Thanks for the tip. I'll let you know how that went.
Oh...I'm sure that the parts catalogue for your my wife's vulva is the same as yours, however after 20 years of marriage I don't get a chance to look at it as much as I'd like to.
Thanks
AJF
Thanks
AJF
Can you get to the online manual for the 1999?
http://new.volvocars.com/ownersdocs/...99sv70_000.htm
2005s60
01-19-2011 01:50 PM
dads 740 turbo
10-24-2008 06:54 PM
