1999 V70XC Oil Leaks??
Old Dec 12, 2011 | 11:23 PM
Matt Lagusis's Avatar
Default 1999 V70XC Oil Leaks??
Where are common spots that these cars leak oil from?
Old Dec 13, 2011 | 10:40 AM
Turbo return line, cam seals, turbo cooling line, rear main seal, PCV system pressure blow off.
The PCV system is the #1 cause of most oil leaks in these cars so service that if you haven't.
Old Dec 13, 2011 | 10:46 PM
how do you service the PCV system on these?
Old Dec 14, 2011 | 10:50 AM
There is a write up in the 850 section, DIY thread.
Old Dec 15, 2011 | 11:39 PM
Ordered my kit from gruton. Engine started leaking bad 1 month ago. Was told by a local shop that it was the front crank seal. Changed it and the timing belt two weeks ago. Hopefully it holds up until I fix the Pcv kit.
Old Dec 16, 2011 | 10:02 AM
Keep your foot out of it.
Old Dec 16, 2011 | 10:51 AM
BPATR1CK's Avatar
On a lighter note, the gasket on the filler caps have been known to leak...
Good luck
Old Dec 20, 2011 | 12:27 AM
cowboy14's Avatar
Some of the common reasons you might experience an oil leak are:
Worn pistons and rings/Bad or worn gaskets/Oil plug not secured properly/Oil plug worn or damaged/Oil filter not attached correctly or missing gasket/High oil pressure (a problem in itself)/Oil coolant line corroded or leaking
Old Dec 22, 2011 | 10:35 PM
new PCV kit just came in. Going to install this weekend. Have been driving the car with the dipstick up and seems to help a ton.
Old Dec 25, 2011 | 08:13 PM
Make sure you clean the EGR if you have one.
dow1971
Jan 7, 2012 09:59 PM
STREETFIGHTER50
Apr 7, 2009 12:21 PM
jklenk
Aug 18, 2008 12:26 AM
jonesje
Dec 29, 2006 11:51 PM
proplasm
Engine & Internal
Jan 25, 2006 06:46 PM
