2.3L T Leak?
Old Oct 11, 2008 | 08:09 PM
tbm5690's Avatar
Default 2.3L T Leak?
My 2001 T5 has just recently started producing an audible high-frequency sound that can be heard mostly when outside of the car and that I have pinpointed to be coming from somewhere on the right side of the engine bay behind the intake box...I was thinking it could be a small leak in one of the vac lines...thoughts?
Old Oct 12, 2008 | 06:08 AM
Default RE: 2.3L T Leak?
When it does it pull the dip stick and see if it stops. If so then it might be a vent box problem.
Old Oct 12, 2008 | 08:33 AM
tbm5690's Avatar
The oil dipstick?
Old Oct 12, 2008 | 10:48 AM
Yes
Old Oct 12, 2008 | 02:09 PM
tbm5690's Avatar
I pulled the dipstick and the noise persisted. When you put your ear behind filter box the high frequency leak sound turns into a hissing leak sound...is the vacuum located in that region?
Old Oct 12, 2008 | 08:10 PM
Check the hoses down by the turbo.
Old Oct 13, 2008 | 07:37 AM
tbm5690's Avatar
The car is at my dad's, so it will be him checking it out...is the turbo back behind the block?
Old Oct 13, 2008 | 08:11 AM
If you follow the bog plastic hose from the air filter box towards the back of the engine it runs to the turbo.
2008XC70
2001-2013 model year XC70
Dec 20, 2017 03:07 PM
ROBLU540
Feb 20, 2009 07:59 PM
1999S80T6
Dec 16, 2008 04:54 AM
