2000 V70 Auto, gear lever select light bulb replacement
Since acquiring the vehicle, the shift **** gate does not illuminate the varying engagements for the transmission (P, R, N, D, 4, 3, L) as you can imagine, this can be quite annoying at night. I have purchased a new bulb and holder from the dealer however am unaware of how to gain access to the bulb itself inside the panel. Any guidance? Thank you in advance!
RE: 2000 V70 Auto, gear lever select light bulb replacement
You need to remove the center console. Under the arm rest lid in the bottom is a cover remove it.
Then remove the 2 8mm screw. The with the lid open and the e-brake handle up some slide the e-brake boot and plastic towards the drivers seat. Then unplug the 2 white plugs and lift the console out.
Lift the back up first the slide back to remove. Then you will be able to see the bulb.
phoenix_iii
01-11-2008 07:15 PM
Qamar
10-14-2005 06:22 PM
