2001 V70 T5 - starting, but wont stay running
I just had my oil changed on my '01 V70 T5 (106,000 miles) at a "not-a-Volvo-garage", highly regarded from a good friend. As I drove off and accelerated, I heard a "pop" and the car started sputtering and stalled at the traffic light a block away. I got it off the road, called the garage and, of course, they weren't sure what was up, so I called the dealer I work with. The tech said it sounded like the air line to the filter housing came off, they may have loosened it while checking the air filter. It did. I reconnected the lower line, checked the upper connection above the radiator and tried to restart. It fired, ran rough for a few seconds and settled back to normal operations. I drove back to the garage to let them know what happened. After a couple of minutes idling, it stalled again and would not stay started. I can still feather and it will stay running above 2000 RPM or so, and I do notice a vacuum "sucking" sound. Any other suggestions? Thanks and sorry for the ramble...
