2004 v70 removal
Old 09-27-2008, 09:48 AM
dcz's Avatar
dcz
dcz is offline
Default 2004 v70 removal
Does anyone know how to remove the radio from an '04 V70 wagon? I got quoted $100 to change it at the volvo place and I cannot imagine it is that hard..
Thanks in advance
Dan
Old 09-27-2008, 02:25 PM
Default RE: 2004 v70 removal
It is kind of a pain because the climate module has to come out as well.
Remove the pen holder part under the climate module. There is 2 screws holding the climate module remove them and pull the bottom some. Then the top slides out. It is alot harder than it sounds. Then there is 2 screws holding the radio in.
Are you installing an aftermarket one?
If so then the Dealer needs to do a download to the car.
Old 10-17-2008, 06:15 PM
I need to do the same thing. Is there anything special that I need to do to prevent getting a code when complete? The last guy that tried to work on myradio set the airbag code. I had to make a trip to the dealer to have the code removed.
Thanks for the help.
rudenko.serge
11-21-2012 12:51 AM
Turbo Shwagon
04-02-2012 06:44 AM
mcnuget
09-19-2011 03:36 PM
The Barron
01-17-2010 08:28 PM
VolvoCyclist
05-03-2009 02:04 AM
Quick Reply: 2004 v70 removal
