98 v70 key wont turn in ignition
Hi. So I get in my car to go get dinner and the key wont turn in the ignition. I can only turn it to I. I dont understand why this would happen because I had driven the car less then 5 hours before this happened. Could anyone help me understand why this would happen and tell me what should be done to fix it?
![EEK!](https://volvoforums.com/forum/images/smilies/eek.gif)
You can probably fix it if it's like the 850. There is a spring in the back of the cylinder and a small pin that holds the cylinder in the hole. What I suspect happens is the pin gets worn or jarred and the cylinder pops part way out. I got mine to pop out then reasembled and put it back in, so far it's worked fine (50k miles). I think if I had just given it a good whack to begin with it would have gone back together (try at your own risk). But what really do you have to loose, you can't break it if it's already broken. A new lock will be pricy as they have to order (and probably make) the one for your car, or your door key won't match your ignition key.
volvoloco
06-27-2011 07:44 PM
