98 V70 making a crazy popping sound when turning.
Old Mar 18, 2010 | 01:25 AM
Budnapp's Avatar
Unhappy 98 V70 making a crazy popping sound when turning.
My 98 V70 AWD 141,000 miles is making a crazy popping metalic sound when I turn left or right going forward or in reverse. It does not make the sound when going straight.
What I have done so far. 6 months ago the CV joint on the right side went bad (grease everywhere). Ordered rebuild kit and repaired. Less than a month later it started making this popping sound when turned in either direction. I figured that my cheep fix with the CV joint rebuild didn't do the trick so I ordered a new half shaft from FCP Groton. I installed the new shaft yesterday then took it for a test drive, and to my supprise the noise is still present. It didn't change a bit.
Has anyone on here ever experienced this? What other areas can I look at?
Old Mar 18, 2010 | 10:11 AM
confused_al's Avatar
Very likely your anti-sway bar end links are shot.
Old Mar 18, 2010 | 02:33 PM
Budnapp's Avatar
Did more troubleshooting. Decided to remove the drive shaft to try and narrow down the noise. Now the noise is gone. So now I am still at a loss. Is the noise coming from the rearend or could it still be coming from the transfer case? Someone help me reason through this. I don't think it is any kind of worn bushing because the sound is too metallic sounding. But I may be wrong.
Old Mar 18, 2010 | 08:53 PM
rcsoundn1's Avatar
IMO sway bars also
Old Mar 18, 2010 | 09:35 PM
I will bet the front joint on the driveshaft is bad. That is a very very common problem.
wondering
Aug 1, 2013 10:14 AM
elcs70
Aug 6, 2012 02:40 PM
02VolvoS40
Feb 12, 2012 06:10 PM
marsar141
Dec 29, 2008 09:50 AM
Athilla
Dec 26, 2006 10:20 PM
