98 V70 XC Idle issue
Old Aug 31, 2007 | 07:47 PM
tinknocker56's Avatar
Default 98 V70 XC Idle issue
My 98 V70 XC, 2.4L Turbo, stalled on my way downtown. I was able to get it running but only at higher RPMs. I backed it back up the drive, parked it. I replaced the fuel filter, cleaned the throttle body. But still wil not run at an idle. I bled the air from the line prior to the filter, and at the injector rack. Fuel pressure is ok as far as I can tell. I don't know what the pressure should read on a gauge though. Also should the fuel pressure maintain the same psi when I turn the key on, as it does when it is running? Any input would be greatly appreciated. I am going to check the psi tomorrow.
Old Aug 31, 2007 | 09:04 PM
Default RE: 98 V70 XC Idle issue
The fuel pressure should be between 45-60 PSI.
It might be a little higher with the car off than it running.
Make sure none of the intercooler hoses have a hole in them.
rosesforlily
Nov 5, 2009 09:23 AM
jettezboy
Oct 19, 2009 12:49 PM
kevmcrae
Apr 25, 2009 11:25 PM
yank50
Mar 14, 2009 11:15 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
