99 v70 code P0138
Old Sep 16, 2009 | 08:31 AM
volvorecycle's Avatar
Default 99 v70 code P0138
I got a 99 v70 with code P0138- 02 circuit high voltage Bank 1 sensor 2.
i replaced the rear sensor, and the same code came on.
the front sensor was replaced at one time, but when i use the scanner to read the voltages, the front sensor doesnt do much switching of voltage.
it appears that the front sensor is bad, but it does not set off a code for the front sensor
i am going to check the wiring from the computer to the sensor for any shorts to ground, then i might just order a new front sensor to try.
has anyone seen any other problems with this code?
Blkwidow
Sep 28, 2013 01:16 AM
Deke MacPherson
Jan 3, 2011 04:32 AM
Elsid
Sep 9, 2010 08:42 AM
badmonkey
Jul 28, 2008 09:15 PM
gzh
Mar 21, 2007 09:29 PM
