Battery drains in about a week
If I don't use my V70 2.4 S over about a week the battery completely drains.
The real pain is that I can only open the drivers door with the key so in order to charge the battery I need to clamber over the seats to get to the battery in the boot to charge it.
At the risk of appearing dim - is there any way of opening the tailgate/doors when the battery is so flat that the remote won't work. I'm 6 ft 4 and 16 stone - if I get wedged in between the seats I might never get back out!
Any suggestions (short of a diet or yoga classes greatly appreciated!)
Edddiec
Edddiec
I'll check tomorrow
Hello, I swear I'm pretty sure there's a rubber plug on the "soffit" above the license plate. You remove the soft rubber plug and you can use your key. I'll check tomorrow. Also, if your car is parked on quiet land, you can run a trickle charger and prevent it from dying cyclically-which is not good for a battery. Kira
shrinking
06-09-2015 09:22 PM
