Bi-Fuel V70 missfires
Old Apr 18, 2009 | 11:02 AM
biggles's Avatar
Question Bi-Fuel V70 missfires
Hi,
I have a Volvo V70,with a factory fitted Bi Fuel system 2002, when it changes to gas the engine seems to miss -fire, which is worse at low speeds, I dont think you can drive thru it in terms of RPM but it seems better at higher RPM. Its been to Volvo Tonbridge and they found a hard fault on the rear Lambda,£300 they changed it also a loose connection on one of the spark plugs, which they charged £70 to fix,,now they say they dont know anything about gas, can anyone suggest a cure?
Old May 29, 2009 | 05:14 PM
tedlet1's Avatar
I had a similar problem with my v70, and the cure was a new igntion lead set
smithnr
Apr 8, 2013 04:56 PM
orcutd
Sep 27, 2008 08:13 PM
the_happy_driver
Jun 26, 2008 12:47 AM
chaniewski
Nov 13, 2007 05:50 PM
edahlgren
Oct 7, 2005 09:53 PM
