Blower motor will not turn off
Old Jun 20, 2009 | 10:08 AM
mkem's Avatar
Default Blower motor will not turn off
I have an 02 V70 which the blower motor will not turn off and kills the battery. I have to pull the fuse to stop it. Any info on what to look for is appreciated. I tried disconnecting the battery overnite but it didn't help. Pulled the plug to the blower motor and there is always 12 volts going to the motor.
Thanks,
Mike
Old Jun 20, 2009 | 11:07 AM
The resistor might have shorted out keeping the blower motor on.
Old Jun 21, 2009 | 10:24 AM
mkem's Avatar
Where is the resistor located and how can it be checked?
Thanks,
Mike
Old Jun 21, 2009 | 10:27 AM
It is hard to test it.
It is located in the blower motor assembly when you remove the blower motor.
Old Jun 21, 2009 | 10:54 AM
mkem's Avatar
I have the motor out now. If you can't test it what do you do buy a new motor?
Old Jun 21, 2009 | 11:01 AM
Sorry to say but usually you have to test with a new resistor. When you slide the motor out of the case you will see the resistor there. Metal fins and screws into the plastic housing.
Old Jun 21, 2009 | 11:08 AM
mkem's Avatar
Do you have a part number to the resistor so i can buy a new one from Volvo? Can you buy them aftermarket?
Old Jun 25, 2009 | 06:41 PM
I believe only Volvo I will have to look it up.
Russk123
Jan 5, 2014 04:18 PM
Jackpeck3
Mar 6, 2011 08:23 PM
itsmy850
Jul 27, 2010 03:32 PM
vvod
Nov 18, 2009 07:30 PM
rspi
Sep 2, 2009 09:39 PM
