Brake help
I am doing a brake job on a 98 V70 and I am having trouble getting the piston back in the bore. I was able to push it back a little bit with a c clamp enough to fit the caliper back with one new break pad and one old one but thats as far as i have gotten it to go. Is something broken or am i missing something?
Yeah I tried all those things since the post and still no luck. I went and did the other side and it went very smoothly. On closer inspection it looks like the boot around the piston has come off a little bit and there is a little bit of rust on the piston. I'm thinking its the caliper so I just ordered one in case it is. Does this sound right and is there much to replacing the caliper. As far as I can tell you just have to disconnect the hose and connect it to the new one then put everything else back together. Any pointers?
Jomo1994z71
01-28-2008 09:05 PM
