Can't open hood of 98 xc70
There's a trick
You pull the latch then go in front of the wagon and slide a pen into the left side latch from the front (over the headlight) to pop the latch
Once you get the feel of it, it's very easy to do.
The other way is to have two people, one to open the latch and hold it while you lift the hood at the center.
It's adjustable..... but that's another story
I have the same problem with my car but I think in his case the latch might be broken. If one side opens and the other doesn't and you are unable to pull it up while someone pulls on the release you are going to have to reach in under the hood and pull on the lever that is on the back of the catch. This is where the cable connects to the release. It's possible the cable is either disconected or broken.
Hood won't open xc70
I did the trick of pulling latch once and opening front, then went back and pulled the hood release a second time and that worked! Awesome! Thanks for the great tip!
JeannieBeannie
03-06-2019 01:29 PM
MDUBBSS70
05-28-2014 09:02 PM
arifiano
06-07-2010 10:06 PM
