Can't put key in ignition of 98 V70
I went out to my 98 Volvo v70 and could not insert the key in the ignition. The key will not go in at all. I tried both keys and neither of them work but they both open the doors fine. It feels like I am hitting a wall.
The steering wheel is not locked nor can I make it lock by turning it. I tried squirting some WD40 in it to see if that would help but no luck. Yesterday the car worked just fine and I have never had an issue inserting the key.
I did read some threads on other sites about a plastic dust cover that is in the way but my v70 does not have this, you can see metal when you look into the ignition.
Does anyone have a thought?
Thanks,
Mike
Thanks,
Mike
Similar thing happened on my 850. There is a small hole with retaining pin that keeps the cylinder in place. From what I figure the retaining pin slipped and the cylinder poped out partway as there is a good size spring behind it. You may try hitting it with something to see if it pops back in. Or you may be able to wiggle it out with a pair of pliers. I got mine out and put everything back and it's been working fine for probably 30k miles. I figure the retaining pin is probably worn and eventually it will hapen to me again.
Ahh, success! I ended up hitting a sharpened screwdriver with a hammer into the keyhole and it separated the 2 pieces of metal that were not allowing the key to enter. They were frozen shut and will likely need some lube. I tried forcing them open yesterday but wimped out on how hard I should force them. I guess brute force is sometimes the answer.
Thanks all!
Thanks all!
returning from work this evening, got to my car, opened the door, but I couldn't get the key to go in the ignition. As if something is blocking the key from going in. went online and stumbled on your post... ![Smile](https://volvoforums.com/forum/images/smilies/smile.gif)
Is sticking a screw driver in ignition an option here... will it cause damage to the lock, will the issue come back next time i stick the key in?
Thanks
Thanks
TrouperL
1998-2000 model year V70
10-30-2012 01:58 PM
volvoloco
06-27-2011 07:44 PM
