CEM/REM on V70
Old 01-17-2009, 02:06 PM
mercury 100's Avatar
Default CEM/REM on V70
Evening All.
Im new to this site so here goes. I got a volvo V70 my back passanger doors,tail gate doorand fuel hatch are dead lockedplus my rear reversing lights, fuel gauge & rear window wiper are not working. Took the car to main dealer today they said its my CEM &REM are at fault which is going to cost £1000 plus. Is there anyway i can get it fixedcheaper.Also cananybody tell me where they can be found on the car, It is a 51 reg
Cheers Mercury.
Old 01-17-2009, 07:53 PM
Default RE: CEM/REM on V70
If they are indeed bad then no there is no cheaper way.
But I would check all the battery terminal connections and connections to the REM. Then REM(fuse panel) is mounted under the panel by the L/R taillight.
The CEM is under the dash on the L/S of the car. You will see a bunch of relays in it.
I have seen bad connections cause this problem quite a few times. It is usually at the battery and cables.
Old 01-19-2009, 07:50 AM
65mustang's Avatar
Welcome aboard. Listen to tech, tech is good, tech is wise.
JenniferXC70
2001-2013 model year XC70
10-25-2022 10:46 PM
Geoff813
05-20-2021 02:31 PM
Raniz
1998-2000 model year V70
07-05-2013 05:35 AM
deeno77
04-18-2013 07:11 AM
tzracer
11-29-2007 06:09 PM
Quick Reply: CEM/REM on V70
