Compression tests
Old Dec 3, 2010 | 05:40 PM
peteman1076's Avatar
Default Compression tests
Hey Guys-
Just curious about what an acceptable compression test result is, also what's bad and what it is when the engine's brand new.
Old Dec 10, 2010 | 02:04 PM
Default anybody? beuhler?
maybe my post before was worded poorly. I was wondering if anyone knows what compression values are when the engine is in pristine condition, what an acceptable range is, and what values signal that the engine needs some work.
Thanks- Pete
Old Dec 10, 2010 | 06:08 PM
ed7's Avatar
ed7
Information in Haynes gives a range of 11 bars to 15 bars with a maximum variance of 2 bars, or 10%. Below that, you'd notice considerable oil consumption. (150-200 psig)
Ed
Old Dec 11, 2010 | 09:00 AM
Georgeandkira's Avatar
Default I can't remember
Hello, I did a compression check in my 1999 years ago.The readings were within 4% of each other. The squirt of oil into each cylinder for the second round didn't change a thing. My old plugs were worn and ashed up identically. I just can't recall the psi reading. Keep in mind that the value indicated on the guage will vary with tool quality, wear and design. If you were near No. New Jersey we could knock this out. Kira
Old Dec 16, 2010 | 05:39 AM
rsxer63's Avatar
We just did a compression test on our two recently purchased 2001 V70 T5s... My car had a engine that was supposedly rebuilt 40k ago... it had 170psi on all 5cyl. Out other car has 118k and it had 160psi to 170psi on it.
clarkr
Apr 22, 2015 11:13 AM
bnuk013
Nov 2, 2006 10:12 PM
rp850
Jan 20, 2006 02:17 AM
wholesale boxes
Aug 17, 2005 12:12 AM
dalborn
Jul 21, 2005 09:52 PM
