Coolant Leaking (posted 3-month ago)
Old Nov 9, 2010 | 07:07 PM
lunanbay's Avatar
Default Coolant Leaking (posted 3-month ago)
Hey Folks
have a V70 XC, just strated leaking coolant (lots) into footwells of car!
Any ideas?? approx costs??
Cheers
Rob
Old Nov 9, 2010 | 08:45 PM
hookuspookus's Avatar
Default oh really ?
Originally Posted by lunanbay
Hey Folks
Cheers
Rob
if it is on the passenger side heater core ! use distilled water when the repair is done
Old Nov 12, 2010 | 05:13 AM
jks2's Avatar
Welcome to the forum. +1 on new heater coil. Don't use just distilled water, make sure it's mixed 50/50 with anti freeze.
Old Nov 18, 2010 | 03:04 PM
markelvis's Avatar
A coolant is a fluid which flows through a device to prevent its overheating, transferring the heat produced by the device to other devices that use or dissipate it. An ideal coolant has high thermal capacity, low viscosity, is low-cost, non-toxic, and chemically inert, neither causing nor promoting corrosion of the cooling system. While the term coolant is commonly used in automotive, residential and commercial temperature-control applications.
Mama
Feb 23, 2025 03:25 AM
pgu44
Oct 18, 2011 09:02 PM
jadedj
Nov 12, 2010 06:58 AM
newvovofan
Oct 22, 2010 06:29 AM
nikez07
Oct 5, 2010 04:01 PM
