Creak from rear
Old Aug 14, 2008 | 03:39 PM
simonb's Avatar
Default Creak from rear
Hi, I have a creak from the boot (trunk) area of my V70. It seems to be when the car flexes, cornering, accelerating etc.
I have tried rear seats up/down, privacy cover off. Any thoughts appreciated as it's spoiling the enjoyment of my car.
Old Aug 15, 2008 | 06:13 PM
Default RE: Creak from rear
What year is it?
Old Aug 16, 2008 | 04:31 AM
rules's Avatar
Did you remove the security cover completely or did you just roll it up?
Mine sometimes squeak a bit at the ends (spring loaded end caps) and I just wiggle it a bit to make sure it seats properly against the side and it goes quiet again.
There sure is a lot of squeaky plastic in these cars, didn't ever think I would have this problem with a Volvo.
Old Aug 16, 2008 | 05:28 AM
simonb's Avatar
Hi, it's a 2005 model.
Yes I did remove the security cover completely.
Thanks for your help guys.
Old Aug 16, 2008 | 06:06 AM
rules's Avatar
While I was staring at the screen I remembered something, it's not about a noise from the boot (but in that region) but I thought I would mention it anyway.
A while back the car had this screechy/squeaky noise whenever I would go over bumps and things and after quite some time looking for the culprit I eventually found that the left hand sway bar link bolt had sheered off but was kept in place by the rubber boot and every time it would "load up" it would rub the pieces together making a nice screechy noise
Old Aug 16, 2008 | 08:12 AM
Check the rear sway bar end links.
Old Aug 16, 2008 | 02:44 PM
rules's Avatar
Sorry, a little off topic here but, I just noticed the little block on the right hand side where it shows the top 10 posters and I realized that tech, you have more posts than the other 9 guys put together ... does your boss know about this
Old Aug 16, 2008 | 07:58 PM
ORIGINAL: rules
Not sure but I started this way before working there.
Old Aug 21, 2008 | 10:56 AM
simonb's Avatar
Okay, car now been checked by Volvo who state not mechanical but panels creaking. They say they have some sound insulating tape they could use to try and deaden it...
Old Aug 21, 2008 | 11:29 AM
rules's Avatar
Strange, mine is much older and I don't have this problem and even though the car is quite plasticy inside, the panels in the back seem to be fairly sturdy.
Ah well, lets see if their magic works
IFGD
Dec 27, 2013 07:50 AM
oreng
Jul 20, 2010 03:22 AM
gilber33
Jul 6, 2010 02:42 PM
Bruno937
Mar 8, 2009 12:41 PM
effeddex
May 18, 2006 08:52 PM
