ECM replacement question
Old May 8, 2008 | 06:35 AM
OK_v70_5spd's Avatar
Default ECM replacement question
I have a replacement out of another '99 non-turbo. Does it matter whether the donor car was automatic or 5 speed, and are there additional issues with an ECM swap? Thanks.
Old May 9, 2008 | 05:44 PM
Default RE: ECM replacement question
Usually on the 99 and up cars the ECU is specific to the car only.
You cant just swap them out.
Old May 12, 2008 | 12:27 PM
Thanks tech. Do you think even if I got an ECU from a same model year, same engine, same transmission V70 I would still be unable to install a used ECU? It seems hardly worth it to pay the cost of a brand new ECU for a 200k mile car. Any alternatives to a new ECU you can think of?
I have a front O2 sensor always reading a flat 0.5 volts in my OBDII scanning software regardless of what sensor I connect to it. The rear O2 sensor works normally and I get a real reading from it. And when there's nothing connected to the harness for the rear sensor it reads 0 volts. So something is really screwy with the wiring or the ECU ports for my front O2 sensor. This electronic crap is really a shame given the car is in pretty good mechanical shape for 200k miles.
Old May 12, 2008 | 05:57 PM
The 1999 cars are networked cars.
The Vin# is programmed into the car. Which means you can't just throw any computer in there.
I have never tried so I can't tell you 100% if it will work or not.
Another option might be to try to have a aftermarket tune done to the computer and see if it fixes the problem.
s60-owner
Jun 17, 2015 06:38 AM
dejan_da_dude
Feb 24, 2015 01:17 AM
mmlco
Aug 31, 2009 05:31 PM
ToddsV70R
Oct 6, 2006 08:55 PM
Kara425
May 10, 2005 09:31 PM
