Parking/Emergency Brake
Old Jun 8, 2006 | 12:26 PM
rmmagow's Avatar
Default Parking/Emergency Brake
The emergency brake on my V70 is not working at all. The handle is firm, the adjuster is very very hard to turn. There's no e-brake action at all other than the dashborad light lights. I spoke to the mechanic who has been working on the car a bit for me and he said worst case, this could run me $600.00 to fix. Huh! Isn't this just a set of small drum like shoes inside the rear wheel hub/rotor? Is the parking brake cable know for rusting up and needing to be replaced? Any suggestions where I can begin trouble shooting. These folks are scheduled to change my T-Belt and WP for $600.00 and I really can't dump another 6 for the e-brake. Are there any trouble-shooting steps i can take to see if I can fix the ebrake? I plan to remove the center console this evening to begin checking things out.
Thanks.
Old Jun 8, 2006 | 08:44 PM
Default RE: Parking/Emergency Brake
I would remove the Rear rotors and make sure everything is moving when the Handle is pulled up.
If so then clean the Brake shoes good and the rotor and see if that helps.
jonathan1280
May 10, 2019 01:44 PM
Wood-Bee-Mechanic
2001-2013 model year XC70
May 11, 2012 12:15 AM
DIYinCT
Aug 4, 2009 03:18 PM
arthur240
Jan 28, 2006 04:52 PM
jcmartin
Aug 1, 2005 06:18 PM
