Erratic Air Pump
Old 11-12-2006, 09:49 PM
Drum R's Avatar
Default Erratic Air Pump
Hi - New to the Forum. I have a '98 V70R AWD with 85K miles. The auxiliary air fan comes on as it should when the car is cold and goes off. It's noisy enough that I can hear it running. Many times when I stop at a light or when I pull into my garage, it comes on again, does its 2 minute cycle, and shuts off again. Any ideas what the cause might be? It does this both with my factory ECU and with my IPD Power Pack ECU, so I assume it's something else. Thanks, Neal
Old 11-13-2006, 12:07 AM
Default RE: Erratic Air Pump
Any codes in the system?
A bad coolant temp sensor will make it come on.
Old 11-14-2006, 11:40 PM
Drum R's Avatar
Tech - no codes, unless I unplug the pump, then I get the appropriate code (forgot the number) on my OBDII reader. Where is the coolant temp sensor? Easy and relatively cheap to install I hope?
Old 11-15-2006, 08:36 PM
The coolant temp. sensor is located in the thermostat housing.
I would do the thermostat and sensor.
It is easier to get to the sensor when you have the upper part of the housing off.
Old 12-26-2006, 06:31 PM
Drum R's Avatar
Tech -The car developed a slow leak in one of the heater hoses last week so I had the thermostat and sensor replaced while the system was drained to replace the hoses. The air pump still comes on intermitently, like when I stop at a light or pull into the garage - at least those are the times I hear itcome on. Any other thoughts? The car has 86K miles. Thanks
Old 12-26-2006, 10:42 PM
Did you check the relay for water?
Also make sure no one installed a Vaccum pump for the brakes.
Old 04-14-2007, 12:43 AM
eyukins's Avatar
I think I have the same issue. The best way to describe the noise is that it sounds like a circular saw. In fact the first time I heard it I thought somebody was inside the garage cutting wood so I did not open the garage door.
The noise seems to be coming from under the driver side headlight. Right next to the radiator/coolant drain valve. This part looks like a smallwedding cake, it could have a fan inside, haven't looked to deep. Anyway the unit seems to have disconnected from the rubber mounts that support it.
ARE WE TALKING ABOUT THE SAME PART?
rspi
03-19-2012 05:38 PM
turboxr
12-17-2011 12:35 AM
vjaneczko
05-03-2010 07:35 PM
SPJC
11-19-2005 09:15 PM
ripleydog
09-16-2005 08:38 PM
Quick Reply: Erratic Air Pump
