fluid leak..
Old Sep 19, 2005 | 05:17 AM
v70 2.4t's Avatar
Default fluid leak..
Hi Guys,
I have noticed a little oil leak, allthough i don't think it's engine oil, it's a black/dark brown fluid and it's a bit thicker than the consistancy of water.... it seem's to be coming from the driver side(your passenger side in the states), it is dripping from the back edge of the front wheel about 300-400 mm in ....any advise would be great.. could it be power steering fluid!!
thanks
Jamie...
Old Sep 20, 2005 | 01:18 AM
Default RE: fluid leak..
Very possible that is is steering fluid.
Old Oct 18, 2005 | 07:06 AM
v70 2.4t's Avatar
Hi Guys, in the volvo hand book it states that only volvo anti freeze coolant should be used because of certain aluminium parts used in the cooling system... my Question is do you have to use the volvo coolant or can i use a valvoline pre mixed G-O5 Anti-freeze - Anti Boil...
Thanks
Jamie... V70 2.4T..
Old Oct 18, 2005 | 08:45 PM
Read the back of the bottle and make sure you can use it with an aluminum engine.
We don't use Volvo coolant.
Old Nov 18, 2005 | 08:16 AM
v70 2.4t's Avatar
Hi, Guys...I have finally had enough of the bloody oil leak, my kid's now have a swimming pool in the garage !! My mechanic who is reluctant to work on VOLVO's and only VOLVO's..He works on anything and everything BMW, MERC, AUDI you name it but not VOLVO, said i have a oil leak coming from the crank case, and another little one somewhere else (can't remenber where). How involved is getting this leak fixed, i might have to take it to a volvo garage, and i don't want to get stitched up!!! Any advise on size and time of this job would be tops..
Have a good one..
Aussie Jamie..
V70 2.4T
Old Nov 18, 2005 | 09:50 PM
The 2 common places for oil leaks are the Vent box.(Front of engine) The turbo return line (Back of engine)
The vent box is expensive to get repaired because the intake has to be removed.
The turbo return line is fairly cheap to have it fixed.
Old Nov 21, 2005 | 03:32 AM
v70 2.4t's Avatar
Hi, I will direct this question to Tech because he respond's to most post's...
Tech, can you please let me know why this oil leak is sometime's there and sometime's not
I can park it in my garage for a week and no leaks , then one day BOOM oil everywhere why is this so, i'm curious to find out..
Thanks
Jamie..
Old Nov 21, 2005 | 09:24 PM
Is it leaking from the front or the back?
If it is from the back then you must go easy on the turbo on some days and other you might hit it very hard.
Old Nov 22, 2005 | 02:38 AM
v70 2.4t's Avatar
Hi Tech & fellow volvo enthusie's
It's leaking from the back...Does this mean i don't drive the car hard enough..?
Because i can fix that no prob's....Like you i also like Speed.
Just a bit of fun, I'll get it checked out and let you all know..
Jamie
v70 2.4t
tcrossley
Feb 1, 2007 10:49 PM
rmclemns
Dec 11, 2006 09:17 PM
myspv
Oct 29, 2006 11:29 PM
my850turbo
Jun 27, 2006 01:29 AM
reg
Mar 17, 2005 07:57 PM
