Front End Shake/Shutter 10998 V70XC
Old Sep 12, 2016 | 12:59 PM
danielak0328's Avatar
Default Front End Shake/Shutter 10998 V70XC
Hello
It's been a while since nothing major has been happening with my Volvo, but now there's an issue I cannot seem to resolve. I have a shake/shutter from the front end, noticeable through the steering wheel at speeds above 65mph...sometimes below 30mph - but pretty smooth in-between. Sometimes it smooths out, somewhat, when I'm on the throttle - sometimes it doesn't. Sometimes it shakes/shutters when I'm off the throttle going down a decline..
I've done the following:
*Wheels Balanced several times, nothing found?
*Front End Alignment, several times, nothing found?
*Replaced: Wheel Brgs, Tie Rods, Lower Control Arms, Stabilizer Links, SubFrame Bushings...(Most needed Changing anyways)
*Replaced Front Drive Axles, both sides, with Volvo and non-Volvo brands
*Removed the Drive Shaft from the Angle Gear to the Rear Differential
Don't know where to go from here? Could it be a bearing in the automatic transmission? (Tranny shifts excellent - last oil change it looked good and no metal filings..etc...)
Help if you can?
Thanks
DAK
Old Sep 12, 2016 | 03:02 PM
firebirdparts's Avatar
It sounds like a tire that is not round or has a bad belt.
Old Sep 12, 2016 | 04:00 PM
easy way to rule out tires is to do a front to rear rotation. also how new are your struts? any sign of leakage? A worn strut will amplify any rotational balance problem (ie tire, axle etc).
Old Sep 19, 2016 | 03:54 PM
Hello.....Well - it's still there. 4 new tires (2 were cupped pretty bad), and I still have a steering wheel shake and shutter that can be felt - apparently from the front end. The struts are fairly new Touring Brand from FCP or IPD - and they were replaced along with the Strut Brgs, all hardware, etc... I see no leaks of the front struts, and I am replacing one of the rear Nivomats that are leaking.
So...I am at a loss on this? I don't know if I need to replace the front struts, or WHATEVER! Is there a definite way to see if one of the struts did go bad? (Getting frustrated at this point and don't want to ruin another set of tires...)
Dan
FriendlyFoe
Apr 5, 2015 01:16 PM
ryan29121
1998-2000 model year V70
Mar 26, 2013 02:16 PM
SeanF
Jan 7, 2012 10:17 AM
one13designs
Sep 26, 2011 09:45 AM
trooperone
Mar 5, 2011 05:33 PM
