HELP 99V70SW front passanger side intermittent noise
Old Aug 26, 2006 | 10:54 AM
hubmachine's Avatar
Default HELP 99V70SW front passanger side intermittent noise
last sunday i took it upon my self to replace the passenger side outer cv boot on my wife's 99V70 nonturbo wagon.
took a while, but finally got it back together. biggest pain was putting axle back in and reattaching the hub.
anyway, driving home heard an occasional knock coming from where i was working. thought it may be the outter clamp buckle hitting something. a couple days later got the car lifted and looked at the clamp. looked ok.
this morning the wife tells me that the knocking is worse.
what are the chances that i screwed up the axle while removing or reinstalling? the old boot had seperated around the axle clamp, but was still full of grease.
also, is there a source for aftermarket axle assemblies for this car?
many thanks
cliff
Old Aug 26, 2006 | 12:17 PM
Default RE: HELP 99V70SW front passanger side intermittent noise
Make sure the upper spring seat didn't break while you were messing with the Axle.
With the car on the ground open the hood. Then try turning the top strut nut it is a 13/16 if it turns freely then it is bad. If it feels rubbery it is good.
you might also want to feel for Play in the sway bar links.
Old Aug 29, 2006 | 08:24 AM
hubmachine's Avatar
tech
i checked the bolt on the strut. seems fine. will try to look at sway bars today.
thanks for your help.
do you know of a source for aftermarket axles? or really good deals on oem?
cliff
Old Aug 29, 2006 | 08:41 PM
Worse case the Axle might break or strip.
Look in your local area and see if you have a CV Pros near you they rebuild and do a good job.
slipperysalmon
May 1, 2014 03:10 AM
RA082324
Nov 20, 2013 10:34 AM
Bert07
Oct 22, 2011 03:05 AM
pcr5946
Nov 21, 2010 03:34 PM
