Turbo leak on 01 V70 T5
Old Jan 20, 2006 | 06:30 PM
howardc64's Avatar
Default Turbo leak on 01 V70 T5
Still trying to figure out why I have this leak on the turbo. Have had it for last 40k miles. Always slightly dirty when I change oil It isn't the return line. Rather, it is leaking what appears to be the air intake side. When I take the turbo to intercooler pipe off, I also have oil coated on the interior of the hose on the charged air output side. This seems like a common condition.
Many people say this is just the dirty PCV going into the air intake. I wonder if my turbo seals are worn?
Oil leak on bottom of turbo
Old Jan 20, 2006 | 09:25 PM
Default RE: Turbo leak on 01 V70 T5
That is common on all turbo cars.
At the dealer they were having us remove the hose. Then take a bicycle tube and cut a peice off of it and install it on the turbo then install the plastic hose and it would help alot.
Old Jan 20, 2006 | 10:26 PM
howardc64's Avatar
Thanks. I'll try the "build your own seal" trick :-) I'll take a look to see how much has to come out. The engine bay of this cars always look worse than the job really is.
rolling2
Feb 12, 2012 05:45 PM
trevy
Sep 20, 2010 11:56 AM
snsrgy611
Apr 10, 2009 11:31 PM
snsrgy611
Apr 6, 2009 07:08 PM
rpm48
Jan 25, 2007 12:14 AM
