hight oil pressure
Old Sep 30, 2015 | 07:45 AM
milpro's Avatar
Default hight oil pressure
i'm having a lot of problem with my 1999 v70 2.4 turbo awd. my car would go in limp mode ,then there was nothing to do,so I would shut the car off and restart it, and it would be ok for a little while.but if I hold the gaz pedal to the floor will it was stuttering, will I was driving it would stop stuttering and drive ok for a will.SO I started with the throdel body,replace that and the mass air flow and the temperature sensor and some relays and some sensor and rebuilt the turbo because I hade oil residue in the air way. so I think I did every thin concerning the air. So i'm down to the gaz ,so I took the gaz pressure it was 56lb constant ,the spec is 40 to 45 lb I think. so I was wondering could I be flooding the motor.THANK YOU FOR ANY INFORMATION
Old Oct 27, 2015 | 11:43 PM
benpineapple's Avatar
You're right, symptoms sounds 100% fuel delivery rated. I think the super high pressure is pointing at the fuel pump relay. Sometimes the relays will run hot, rather than failing altogether.
Here's a test that helped me diagnose mine when it failed:
Hope that helps
JSenecal
Jan 3, 2014 12:17 AM
brettboze
Mar 26, 2012 06:25 PM
Ralph
Mar 2, 2010 03:12 AM
97GLT
Dec 24, 2007 08:38 AM
