How many fault codes can you fit in one Volvo????
TCM-002F Lock-up function Slipping or not engaged
TCM-0100 Control module Faulty signal
AUM-47FF Amplifier Faulty installation
AUM-41FF Amplifier, sub-antenna Signal missing
CEM-1A59 Communication with AUM control module Signal missing
CEM-6A01 Door unlocked, left rear signal too high
CEM-1A5F Communication with ABS control module Signal missing
CEM-1A62 Communication with ECM control module Signal missing
DIM-0006 Orange warning lamp Faulty circuit
DIM-FFFF No eroor code description
DDM-0049 Control module Internal Fault
Symptoms
occasional clunky gear shifts (only when hot. When it starts to do this i shift manually and she's a lot better but not perfect)
Hissing brakes
Slightly reduced performance, slow shifting, slow throttle response
Its pretty good to drive now. I'm not in a desperate hurry to fix anything. I would like to get the performance to a level that i don't regret buying an auto. I always said I never would, why i did i'm not sure. But i still love her.
2000 (2G) V70 T5 Geartronic
Symptoms
Hissing brakes
I've been trying to think of the safest way to write it off. The Harbour is looking like an attractive option.
Just kidding. Very little of what is wrong with her is obvious to me so i really enjoy driving her. And until that changes i won't be spending a fortune to fix anything. But I will be keeping a close eye on her.
The dealer's main concern was the ABS module. The ABS message only comes on internittently at the moment. Even though it reads as a permanent fault.
My Transmission Service Required message hasn't returned since i had it cleared and the transmission is running beautifully since my last flush. just the very occasional and almost unnoticable knock changing down in to 2nd. I'm glad i didn't fork out the $6K for a new tranny when Volovo 1st told me i needed one.
Uncle, If you log onto ebay Usa, there is a guy that rebuilds ABS Modules
with a life time warrenty, they are quite easy to pull out.
might be worth a look he charges $75.00US about $100.00AU+ shipping..
V70 2.4t
V70 2.4t
The torque converter isn't locking up. Someone on here may be able to answer better on the function of how it works.
Never really messed with the internals of the trans or torque converter.
Try having the ABS module rebuilt.
gentlejax2
Apr 16, 2011 09:53 PM
1990TURBO740
Dec 25, 2006 04:23 AM
