How to remove oil lins from radiator 2000 V70
Old Mar 13, 2010 | 03:34 PM
bobcat123's Avatar
Default How to remove oil lins from radiator 2000 V70
How do you remove the oil lines from the radiator of a V70 ?
Old Mar 16, 2010 | 01:10 PM
cn90's Avatar
Is this ATF lines?
Old Mar 25, 2010 | 03:28 PM
Georgeandkira's Avatar
Default Bobcat, Did you get it disconnected?
Hello, Your question about disconnecting the transmission cooling line; did you get an answer? Was it "green press clip" or the aluminum cage? I swear the most important thing is to have thick leather gloves on when the line pops out. You can really bang your hands. Kira
Old Mar 25, 2010 | 05:40 PM
VTBricked's Avatar
The tool I like to use on the cage clips is a c-clip plyer. Catch the plyer tips on the clip, squeeze to spread and pull the line straight out. Access is tight, so I second the gloves suggestion.
If the cage clips are old and rusty, buy some new ones so you'll be ready if the old ones break.
Old Mar 26, 2010 | 06:30 AM
bobcat123's Avatar
Default Fixed
I was able to remove the oil line with direct pressure, it turned out to be easy. I did replace the o rings and the green clips when I re installed the oil lines to the radiator.
Can any one tell me who's bright Idea it was to put in a plastic radiator?
mikeawd850
Nov 30, 2012 02:26 AM
darnshepp
Aug 18, 2011 08:48 PM
bobcat123
Mar 13, 2010 08:13 PM
mortonight
Jan 23, 2010 08:34 PM
enigma9011
Sep 1, 2008 08:06 AM
