issues with both power seats...
Old Oct 14, 2010 | 08:08 AM
V70_AWD_t's Avatar
Default issues with both power seats...
hi everyone - new to the board - '98 V70 AWD Turbo 178K - just purchased - timing belt replaced & water pump replaced at 156K +/-
NOW -
the drivers seat will go in reverse fine, however will not go forward unless you sort of push the switch in, basically you have to mess with it. i can move up and down as well as move the back forward and back
would this be just a bad switch?
the passenger seat hardly works at all...occasionally i can get the back piece to move forward, but its basically STUCK in the 'gangster lean' position....very annoying when new people get in the car...
also, when i turn the car off i hear a faint 'tiiiiinngg' from the seat...almost like some sort of electrical disturbance/cross? i did look under the seat for crushed wires and such, and all was well.
heating elements work on both seats.
thank for the help everyone - this is my first volvo...actually my first anything but an acura and i plan to do whatever needs to be done on it myself (within reason haha)
~joe
Old Oct 15, 2010 | 10:11 AM
V70_AWD_t's Avatar
anyone? lol
Old Oct 16, 2010 | 08:19 PM
willem's Avatar
no help on that one.. My V70 T5 has the same... everything works, but ,moving the seat forwards.
Old Oct 16, 2010 | 08:23 PM
It might be seat switches on both seats.
The sound not sure on. Have you listened by the seat and had someone shut the car off to try to isolate the noise?
Old Oct 18, 2010 | 07:52 AM
V70_AWD_t's Avatar
hmmmmm alright - i guess i will just have to start taking it apart ever so slowly to find the root cause of this problem...
the noise is def coming from the pass seat. im thinkin there may be some sort of minor short causing it....just thought maybe others had encountered it in the past
thanks everyone
joe
EastCoastVO
Feb 12, 2015 07:18 PM
mechanicboy
Mar 25, 2014 02:23 PM
jmature
Aug 18, 2010 08:18 PM
agood
Jul 9, 2008 07:58 PM
laylasmom
May 9, 2008 07:31 AM
