Large Oil Leak - Help!
Old Dec 8, 2010 | 04:35 PM
zero324's Avatar
Default Large Oil Leak - Help!
My wife's 01 V70 non-turbo started to leak alot of oil about a week ago and from a quick look under the car it all seemed to be coming from the bottom of the oil filter housing so I thought that maybe some how it got cracked so today I did an oil change and cleaned up all the oil from under the car and frame. After about 10-15 min of the car running and not moving I noticed it was leaking the same amount but could see that it was not coming from the oil filter housing but above it somewhere but am unable see where it could be leaking from. It seems to have leaked about 1/2 to 1 quart since it's started about a week ago.
Here are some pictures that I took from where the oil seems to be leaking from.
I greatly appreciate any help with this.
Old Dec 8, 2010 | 10:04 PM
zero324's Avatar
Well after taking the timing cover off I may have found the leak. It seems like it's coming from either the crank or cam seal. I also notice oil coming from the bottom of the dipstick tube but i'm not sure if it's coming from there or the flame trap box above it. I guess one good thing about the leak is that I found that my water pump is leaking so I guess it's one good thing to find before it fails.
Here are the pictures of what I found. Has anyone else ran into this before?
2008XC70
2001-2013 model year XC70
Dec 20, 2017 03:07 PM
Submoofer1
Jan 9, 2013 04:39 PM
htowncourier
Jul 7, 2008 10:33 AM
sdeering
May 22, 2007 12:55 AM
