need help po107
Old Jun 15, 2009 | 09:08 PM
Dozer520's Avatar
Default need help po107
getting error code po107 on my 98 v70 xc awd. can i get some help trouble shooting this? maybe vacuum leak or MAS? thanks
Old Jun 15, 2009 | 09:40 PM
I would check for leaks first.
Or the map sensor might be bad.
Old Jun 18, 2009 | 07:32 AM
Dozer520's Avatar
where is the map sensor located?
Old Jun 18, 2009 | 08:39 PM
Check and see if it is mounted just infront of the washer fluid fill tube.
Old Jun 19, 2009 | 04:28 PM
Dozer520's Avatar
i understand the sensor that is near the windshield washer fill to be the altitude sensor. and i believe that it is the sensor that is somewhat prone to failure atleast moreso than the sensor that is in the airbox.
the error code that i'm fighting is the po107 and when i disconnect the altitude sensor it goes away and is replaced by po108. so i feel i'm close to diagnosing the problem with that sensor by the windsheild washer fill. it is the only thing that i have unplugged or messed with that has made the po107 go away. does that make any sense? i have checked for leaks and have replaced some old vacuum line connectors as well.
Old Jun 19, 2009 | 07:22 PM
That might be the one. If unplugged it might just throw a different code.
P.S. half of volvo's sensors are also called map sensors LOL
Old Jun 19, 2009 | 09:51 PM
Dozer520's Avatar
well i bought the altitude sensor so we'll see if that clears the po107 code. i'll keep you posted. thanks
Old Jul 24, 2009 | 10:17 PM
Dozer520's Avatar
altitude sensor has been on national backorder so i found an alternative solution. used the altitude sensor from an 86 audi and it works great. cleared code and runs great.
Old Jul 24, 2009 | 11:20 PM
Glad all is good now.
Mavericks
May 31, 2011 02:07 PM
Sanel30
Feb 18, 2010 09:16 PM
texan_176
Oct 4, 2009 10:05 PM
chef
May 19, 2009 05:57 AM
Svtfiveoh
Apr 15, 2008 06:51 PM
