O2 sensor repalcement
Old Mar 11, 2006 | 07:44 PM
hubmachine's Avatar
Default O2 sensor repalcement
is it very difficult to change the o2 sensors on a v70 SW non turbo?
are universal ones ok?
thanks
cliff
Old Mar 11, 2006 | 07:47 PM
Default RE: O2 sensor repalcement
It is not that hard. Atleast buy Bosch o2's. That is who makes them for Volvo.
Old Mar 11, 2006 | 10:46 PM
hubmachine's Avatar
i scored a couple of sensors. looking for info on where to find the one ahead of the catalytic convertor.
anyone out there with info?
tia
cliff
Old Mar 11, 2006 | 11:29 PM
Have you checked out the links to parts sites in the general section?
Old Mar 11, 2006 | 11:55 PM
hubmachine's Avatar
i am not sure what you are refering to
Old Mar 12, 2006 | 12:33 AM
https://volvoforums.com/m_7593/tm.htm
Click on link.
Old Mar 14, 2006 | 07:19 PM
eyukins's Avatar
Just did this.
Go to your local auto parts store and buy a Oxygen Sensor Socket. It has a slice in it to allow for the wire. With this tool, and some penetrating oil you should be able to replace both sensors in about 1/2 hour.
Also, helps to remove the driver side front tire to get at the connectors. (remove and replace connectors 1 at a time so you don't mix them up)
soduku007
Oct 7, 2019 04:01 PM
mctan
Feb 2, 2010 03:16 AM
sabydady
Jul 7, 2009 04:58 PM
MaxBoost13brx
Nov 5, 2008 10:05 PM
