OBD emissions flag and other issues
Old Jul 14, 2006 | 01:00 AM
bconley's Avatar
Default OBD emissions flag and other issues
Hi all.
I have recently turned 16 and was given a 1998 Volvo V70 AWD by my father. It is an AWESOME car to say the least. Very responsive and I love the stiffer sport suspension. However there are a few problems with it that I was hoping you could clear up. I just took it in for its inspection and it passed. However in one of the fields it reads OBD TEST: ADVISE. It then explains at the bottom of the result sheet that the car's OBD computer has detected a defeciency in the emissions system and that the car should be brought to a mechanic for inspection. This worries me a little since the car does put out a lot of steam from the exhaust pipe, especially when idling. Could this be a problem or do all V70's from this era "steam" a lot? Is this normal or is this the fault in the OBD sensor? Another issue is that when the lights are on in the car and the car is running, they flicker a little bit, not a lot but its noticable. My dad says its been doing this for years. Is this normal or is it and alternator issue? A fuse issue? I am starting to make a list of small issues with the car that I just want to make sure are normal for a car with 144080 miles on it. Any suggestions or opinions are appreciated. Thanks in advance!
Brennan
Old Jul 14, 2006 | 09:56 PM
Default RE: OBD emissions flag and other issues
If your Check engine light isn't on don't worry about it.
If you are talking about the Dome lights I have noticed that is about normal.
safetypro79
Jan 3, 2011 08:32 AM
usawebx
Sep 2, 2008 06:11 PM
agood
Jul 9, 2008 07:58 PM
tthrivi
Aug 11, 2007 10:07 AM
jmc00v70
May 25, 2006 06:53 PM
