Oil in Coolant Resevoir
Old Jun 7, 2010 | 11:14 PM
Jakeman's Avatar
Default Oil in Coolant Resevoir
Have a 1998 V70 GLT with 165,000k. I found brown milkly sludge in the coolant reservoir. There is no coolant on the dip stick, or underside of oil cap, and the car runs fine. Could the oil be coming from the radiator or turbo, and is there any way to conclusively find out?
Last edited by Jakeman; Jun 7, 2010 at 11:55 PM. Reason: Words spelled incorrectly
Old Jun 8, 2010 | 08:06 AM
SVTfocusO3's Avatar
It's hard to say, I believe these might have the oil cooler on the pan that goes bad, but does not leak into the motor. If it does not have this cooler, then I would say the radiator.
You should replace all the rubber hoses, thermostat, gaskets, etc. in the cooling system but that's your call. Cascade powder works good as a cleaner, dissolved in hot water 1st.
Old Jun 9, 2010 | 11:56 AM
Jakeman's Avatar
Thanks. I am going to have the radiator checked tomorrow (1st), and then perform a compression check on the cylinders. If these check out, I"ll look at the Turbo.
RestrictedAccess
Jul 13, 2010 12:53 PM
m2point1
May 30, 2008 06:02 PM
RedTurbo850
Jun 21, 2007 08:47 AM
NoleWithAVolvo
Jan 25, 2007 12:10 AM
mikeys
Aug 23, 2006 10:20 PM
