Oil light 4..5sec.after cold start.
Old Nov 29, 2021 | 02:11 PM
Drive4u's Avatar
Default Oil light 4..5sec.after cold start.
120kw d5 2003, after changing the engine every morning when starting the engine the hell lamp lights up for about 5.sec. Causing an error for a few seconds. maintenance is ok. This is an oil pump or some other problem
Old Nov 30, 2021 | 10:12 AM
do you have the correct weight oil and filter type? You may need to drop the pan to see if there's some debris or sludge clogging the pick up. Next is to check/clean the connection/wiring to the oil pressure sensor and consider swapping in a new sensor to get a trusty measurement.
Old Nov 30, 2021 | 01:05 PM
Drive4u's Avatar
Oil is ok Eneos A5,B5 5W30.I check first thinks.
pablogiovani
Engine & Internal
Dec 10, 2012 08:29 AM
Jim-Mer
Sep 21, 2010 06:28 AM
dman777
Mar 24, 2010 04:53 AM
sick_boy93
Apr 4, 2005 09:42 PM
