p0336 plus some strange behavior.
Old Apr 5, 2014 | 02:23 PM
98XCFxRUpR's Avatar
Default p0336 plus some strange behavior.
Just picked up a 99 v70 base model. Changed the timing belt/water pump plus PCV stuff. Also replaced the crankshaft position sensor because of p0336 and p0335 codes.
Got everything back together and it started and ran smoothly, but I'm still getting a p0336 code. I erase them and occasionally get a CEL with no code... But usually get the p0336 back.
Another oddity is that the overhead map lights fade out and then get bright every 10 second or so. I also have abs and brake lights on but I figured I need to replace the abs module.
I could use advise on where to look next.
Thanks
bit_eimer
Jan 25, 2014 12:25 PM
Giorgi.Varamishvili
Jun 11, 2012 11:30 AM
JimBee
Nov 5, 2010 10:16 PM
ivrylineslead
Jul 10, 2008 08:13 PM
DontaviousJones
Feb 29, 2008 05:51 PM
