2000 S70 GLT/SE Transmission Strange Behavior
Old Jun 7, 2012 | 03:11 PM
Giorgi.Varamishvili's Avatar
Default 2000 S70 GLT/SE Transmission Strange Behavior
Hello
Last Few Weeks I experience weired Behavior with my car's Transmission:
After Driving 10-15 miles after Car becomes completely warm in City Cycle, I experience Folowing Problem:
During Starting the car on 1800-2300 Rmps when shifting from 1st to 2nd (and only from 1st to 2nd) gear i notice a continuous vibration for about 1-1.5 seconds and after that the gear is being changed.
if I start the car on less RPMS (linke 1500-1600) the shifting is normal and the same when starting on Hight RPMS (from 2500 - 3000)
I also noticed that when the car is newly warmed up same behavior is not happening.
First Thing I did, I Completly flushed the Transmission fluid - the fluid was completely clean and it had a very light smell of burn. Apparenltly it is normal after 20k miles of driving. Flushing did not help.
so I think may be tranny is not the case
Also it is strange for me that there are no any CEL or other lights appearing on dashbord. I did a diagnostics with VIDA and it did not find any kind of damage or problems.
Do you have Any ideas, what would be the problem ?
The car is well maintained with 151K miles on it
I would appreciate any kind of Help
Best Regards,
Giorgi Varamishvili
Old Jun 7, 2012 | 08:06 PM
Any idea how old the mounts are? The CV axles?
Old Jun 7, 2012 | 11:14 PM
If you mean Motor Mounts, They have been never changed and when inspecting visually they are good.
CV Axles also come from factory
Old Jun 11, 2012 | 10:10 AM
AZvolvoMan's Avatar
Looks like you have the same problem as me. I flush the fluid and idnt change anything. I also dont have any CEL or other lights lid up, which there could be a code if i hook it up to a pro scanner. I only drive it in the city, but if i get the freeway, one i hit 65+ it feels like i need another gear since the RPMs are at about 3k. I might just take it to a profesional transmission shop. Might be the torque converter since the tranny shifts smooth.
Old Jun 11, 2012 | 11:30 AM
Henry Jones Junior's Avatar
My guess is torque converter. I just had this happen and needed to put in a new tranny. My eventually got stuck in lock-up and would stall in anything except park and neutral...
bit_eimer
Jan 25, 2014 12:25 PM
mphilleo
Sep 28, 2013 05:59 AM
JimBee
Nov 5, 2010 10:16 PM
ivrylineslead
Jul 10, 2008 08:13 PM
DontaviousJones
Feb 29, 2008 05:51 PM
