Power Steering Pump
Dealer pointed out moisture on the ledge of my power steering pump just below the shaft that holds the pulley and informed me that I would need to replace the pump when the leak becomes a drip. They quoted $760. Considering how accessible this part is their quote seems excessive.
IPD lists the pump at $373 and Euro Parts Direct lists it at $275. Any recommendations on these sources or others?
It appears to be something I can do myself since it is so easy to get to. Am I missing any potential problems?
Last question - should I replace it now or wait for the leak to get worse?
Hello, Keep an eye on fluid level. It might just seep for a long time. Since you're in no rush, pop in on junkyards. I paid $40 for mine. You need only slacken the serpentine pulley, disconnect the hose fittings and reach the mounting bolts through the face of the pulley. There are holes in it. What year is your car? Kira
I picked up a pump last year from a junkyard in Shelby, NC for $35 which included a 90 day warranty.
When ya get a chance check the back of your power steering reservoir. I recently found that my reservoir is weeping from the center rear so I will be ordering a new one soon. Also check the lower hose clamp like paul c suggested as mine came loose a few months ago.
scrap88
04-07-2010 09:23 PM
katiejoyful
12-12-2007 04:49 PM
