Question about crankshaft pulley 2001 V70
Old Apr 24, 2017 | 10:07 PM
Frank45's Avatar
Default Question about crankshaft pulley 2001 V70
Working on my wife's Volvo V70 2001 2.4T. Bought it last year with low miles (59,000) and it drove great for 20k more miles until the PCV clogged and started an oil leak by crankshaft/oil pump area. The oil killed all of the suspension parts in the process. Long story short I replaced the entire PCV system with Volvo parts. I've learned that I hate banjo bolts and the damn copper washers. I replaced all the wire looms that were crumbling apart. Replaced on both sides all control arms, ball joints tie rods etc. Now I'm just left trying to stop the oil leak and do a timing belt change.
I already replaced the water pump, timing belt pulley and tensioner. I degreased everything before hand and did locate the leak somewhere around the crankshaft seal/oil pump. I locked the cams from the rear with the cam locking tool. I'm going to pull the crankshaft pulley off this weekend and replace the seal and replace the oil pump. I purchased a seal installer so it will go in evenly. How does the pulley go back on as the shaft has just a nut and not a bolt? Do I tap the pulley back on a bit until the nut can go back on and then just crank the pulley back on with the nut?
I'm sure this process is going to move the crankshaft back and forth so is that ok just as long as I put it back to the timing mark?
Also is there anything I should watch out for when replacing the oil pump?
Thanks for any input!
theonlytjm
Aug 17, 2017 11:28 PM
lummert
Feb 22, 2008 04:45 PM
act1292
Nov 10, 2007 08:41 AM
rmcmighty
Aug 18, 2007 01:23 PM
azeezn
Jun 3, 2006 11:28 AM
