radio
Old Jul 5, 2011 | 12:40 PM
df123's Avatar
Default radio
My battery died and now the radio will not turn on and just says off. what do I do??
Old Jul 5, 2011 | 06:50 PM
Check the STICKY'S
41. Radio Wont Come One - Where Is the Security Code?
Cannot start radio after putting in new battery
Old Jul 9, 2011 | 07:17 AM
Crush's Avatar
leave the radio on for couple hrs. then put in the radio code. if you try 3 times and fail, start over. if no code avaible go to the dealer and they can get it.
crush
Old Jul 11, 2011 | 09:15 AM
df123's Avatar
Default radio
need radio code even serial#V01030 V0070154C AND VIN#YV1LW5674W2446883 i had repairs done and my son typed random #'s when code popped up now it says off please help me??????
Old Jul 11, 2011 | 06:50 PM
kevcan's Avatar
Smile Radio anti-theft system (RATS)
The RATS is meant to prevent stolen radio from being used by thieves. Who would want to steal one of these is the real question..aint like it would fit into any conventional dashboard...but anyhow...if your radio display says OFF and you cant locate the little card that says Volvo Stereo and has a 4 digit code on it, you will need to contact a Volvo dealer to get the "code". Once you have the code you need to turn your ignition on to the number 1 position, turn the radio on, and then wait for 2 hours for it to reset to the CODE display. Then enter the code and you'll be off to the races again !! Remember, you only have 3 attempts to enter correct code or you will have to start all over. Good Luck.
Old Jul 11, 2011 | 07:33 PM
You can also keep driving the car around and when you hit the 2 hour mark the radio will display CODE again. I was surprised when it happened to me.
Old Jul 12, 2011 | 02:30 PM
kevcan's Avatar
You got lucky with that....my 1999 v70 insisted that I leave it in the #1 position for a full 2 hrs....the manual says to make sure lights are off to help conserve battery life. I wonder now whether disconnecting battery again would have caused it to return to the enter code prompt instead of waiting?
Old Jul 13, 2011 | 04:44 PM
Crush's Avatar
well i don't if it will make the code come up if the "off" is up on the display. i do know if you disconnect the battery when it is working right then code will display when you re-connect the battery.
crush
Old Jul 13, 2011 | 04:52 PM
df123's Avatar
thanx for everyone's help. I called the volvo number and got the code left it on for 2 hrs and code came on and i entered it yeah!!! just disconnecting battery and reconnecting did not work just had to wait 2hrs. thank you thank you thankyou
Old Jul 14, 2011 | 10:31 AM
df123's Avatar
crush, i am confused at the last message, I know I used to have a car that the a/c used to switch to econo mode and i would undo battery and it would re-set the system and then it would be cold air again. For some reason I could not accomplish the re-set with the volvo battery. Waiting 2hrs was frustrating yet it finally worked.
Old Jul 14, 2011 | 10:57 AM
The car has to be on for 2 hours for the radio to reset. Disconnecting the battery will not work for the radio.
Old Jul 18, 2011 | 06:20 PM
MichelleDW's Avatar
Ok, so yesterday I thought I needed a starter but it was the battery. Of course the radio did the "off" thing because I couldn't stop myself from punching in random numbers. My question is, my lights will not turn all the way off, the the running lamps/turn signal lights still stay on. Will this not drain my battery if I leave key in position 2 for 2-3hours??? Can't afford another battery. Someone else mentioned pulling fuse #7 to reset. Is that an option?
Old Jul 19, 2011 | 05:05 AM
Man, you guys are killing me. You can go around the block 17 times if you want, the store doesn't open for 2 hours.
You can turn your running lights off for good if you'd like. I think that has always been a stupid feature for most people anyway, unless you live where it rains for 70% of the time or in Alaska where it's dark 70% of the time.
Old Jul 21, 2011 | 06:38 AM
df123's Avatar
i would love to turn the lights off during the day!!! HOW????
Old Jul 21, 2011 | 07:32 AM
Instructions out of the owners manual:
Operation: https://www.customers.volvocars.com/...0_022.htm#pg22
Instructions: https://www.customers.volvocars.com/...0_022.htm#pg26
cbgav
Sep 10, 2007 05:25 PM
