Seals and gaskets
Old Jul 9, 2022 | 11:34 AM
Soldado73's Avatar
Default Seals and gaskets
So I have a 2001 v70 2.4t wagon. So there's not a massive oil leak but enough to leave the dipstick dry by morning. I've narrowed it down to cam seals based off the amount of oil in that area. I'm steal cleaning down the block from under. The drain plug had no gasket also I'm gonna check oilpan just to rule it out. Any other gaskets or seals would you recommend before I put oil back in?
Old Jul 9, 2022 | 01:27 PM
Originally Posted by Soldado73
2001 v70 2.4t
Dipstick dry by morning? 2 quarts a night?
If it's leaking when it is running and the timing belt is wet - (not leaking 2 quarts from the cracked oil pan when sitting)
The cam seals will leak if the PCV system is clogged - and a 22 year old Volvo will have a clogged pcv system - unless that job has been done recently.
The VVT gear can leak also unfortunately.
mpe
2001-2013 model year V70
Jan 28, 2016 02:01 PM
JoeCool850
Dec 9, 2015 12:53 PM
volvovince
May 10, 2014 06:05 PM
dlleo
Feb 29, 2012 05:31 AM
endneu913
Nov 21, 2010 10:53 AM
