Sensor Problems
Old Jul 10, 2011 | 08:50 AM
Volvos Roc's Avatar
Default Sensor Problems
I got this message when my car broke down:
Scan Computer System for Codes. Had Code PO305 # 5 Cylinder Miss Fire.PO128 Coolant Temp Code PO032. Bank One Sensor One Oxygen Sensor Heater Code Replace # 5 Coil for Miss. Test Drive for Miss Ok at This Time.
That was exactly 2 weeks ago. Now the same problem.
Please can anyone tell me what this means.
I have a 2001 V70 with 134k miles.
Volvos Roc
Old Jul 10, 2011 | 09:04 PM
Georgeandkira's Avatar
Hello, Does, "Now the same problem" mean that the P0305 code and miss returned as well as the other two? Regarding the P0128 code; a new OEM thermostat fixed me right up. Many say to change the coolant temperature sensor and thermostat at the same time. It makes sense since you're already into lowering the coolant level or spilling the stuff. Perhaps a failed-open stat made your engine run rich and burned your oxygen sensor. Kira
Old Jul 11, 2011 | 06:30 AM
Crush's Avatar
i agree replace the thermostat and ect (engine coolant temp sensor), but i also think you need at least on O2 sensor. i would do all of them but that is me, and it can be costly. what is considered broke down?
crush
soduku007
Oct 7, 2019 04:01 PM
ruggles
Mar 3, 2010 04:19 PM
mctan
Feb 2, 2010 03:16 AM
Scanman
Jan 28, 2010 07:01 PM
sabydady
Jul 7, 2009 04:58 PM
