Speedometer and Oddometer Quit
Old Jul 23, 2008 | 07:34 AM
JimKW's Avatar
Default Speedometer and Oddometer Quit
On my 98 V70 GLT the speedometer and oddometer will quit intermittendly then come back on again. Read that it could be a sensor on the tranny. What sensor would that be and is it a diy job?
Old Jul 23, 2008 | 06:50 PM
Default RE: Speedometer and Oddometer Quit
I would say ABS module before a sensor.
Old Jul 31, 2008 | 10:06 AM
Rsterns's Avatar
Default RE: Speedometer and Odometer Quit
I agree with Tech that its the ABS. I just removed mine for repair and in doing so the speedometer and odometer immediately stopped working. That tells me that the circuit routing is through this device. Most likely a connector pin with a bad solder joint. My personal opinion, is that DIY on module solder repair is risky. I opted to pay Module Master $150 (including new mounting screws), to assure it gets done right. Hope this helps.
Regards,
JimKW
May 25, 2013 02:44 PM
cshields
May 23, 2010 01:13 PM
chassy
Jan 3, 2009 10:08 PM
onebads80
Nov 7, 2008 09:15 AM
onebads80
Nov 7, 2008 09:03 AM
