srs light on
Old Nov 5, 2006 | 07:22 PM
hubmachine's Avatar
Default srs light on
after replacing the heater core and mopping up all the anti freeze, including removing drivers seat. got it all back together and now the srs light is on. was there something i did in the process that may have caused this fault? can it just be reset?
what might i have done to cause this?
thanks
cliff
Old Nov 8, 2006 | 08:31 PM
Default RE: srs light on
Sorry I forget what year it is.
Some if you turn the key on with the seat out will set the SRS code.
You will just need to have it cleared.
Old Nov 9, 2006 | 09:56 AM
hubmachine's Avatar
tech
it is a 99 V70 wagon.
a buddy of mine has a business installing airbags. he has a scanner and read the codes. they didnt seem to make sence, however.
a series of one digit number i think something like 4,1,0,2 undefined.
anyway, he reset the light and restarted the car. the light came on momentarily, went out, then came back on.
any more thoughts? we looked closely at the orange cased wires that connect under the drivers seat and run up the pilon to what appears to be some sort of pyro device attached to the seatbelt.
thanks for your help.
cliff
Old Nov 9, 2006 | 08:56 PM
I would have to know what the codes were for.
On the 99 it is a networked car and would be a 3 digit code.
SRS 410 is a sips bag signal missing.
lister99
Dec 28, 2012 10:46 PM
Danigirl
Feb 22, 2012 01:36 PM
guptash
Nov 19, 2011 04:17 PM
Sparky4688
Sep 26, 2009 06:22 AM
strauss8
Apr 23, 2004 07:42 PM
