Stored Turbo Wastegate Control
Hi...
I am new to this board, but I'm hoping to get some advice before I take my car in, so I can be prepared.
Over the past few weeks, about once every two weeks, while stopping, my car feels like it's going to stall. If I give it a little gas, it stops after a few seconds and resumes its normal rpm rate (about 900 at a stand-still). The first time it happened, the check engine light didn't come on right then, but came on a day later. When I took it in, the garage said they didn't see anything.
I had replaced the thermostat earlier this winter and then they replaced it again about a month ago.
The semi-stall happened a few days ago and the shift arrow came on and so did the CEL. I was in a parking space, so I just turned it off. When I came back a few hours later, it started up right away and drove well. I took it to the garage again and when they checked it, they said that the code was indicating a "stored turbo wastegate control" intermittant error.
The code may be DTC P0243. They said I could drive the car, but to take it to a specialty repair place or the dealer. Before I take it in, I'd like to have some idea of what is going on because I don't know much about cars, and don't want to get screwed by them upselling me a lot that I don't need.
The car is a V70, 1998 with about 136k miles.
Thank you so much for any help and advice you can give me. Since it's the long holiday weekend here, I can't really do anything until Tuesday, but I do have to drive it a little until then.
Thanks... that is the code that's on the bill (I had them do an oil change while it was in). This is the third time I have had the car in - 4.28, 5.9 and then 5.21.
The code from the 28th is DTC P0117 intermittant temp sensor signal.
Thanks!
Thanks!
ENDEE666
Jan 29, 2024 01:33 PM
timer00
May 21, 2009 07:21 PM
luke8_8
Jan 30, 2009 04:02 PM
tcrossley
May 20, 2006 12:50 AM
