Thermostat ??
Old Oct 31, 2007 | 11:40 AM
bansaw's Avatar
Default Thermostat ??
Yesterday my blower motor ceased working, made a few grindy sounds and stopped blowing all together
i tested the resistor and it seems fine so i located a replacement blower motor.
when i was driving to work yesterday i noticed my water temp gauge was not reading and i'd been driving for a while. could blower failure and no water temp reading be related?? and whats broke to not read my water temp
Old Oct 31, 2007 | 07:21 PM
tripleb's Avatar
Default RE: Thermostat ??
Sounds like a coincidence. The thermostat needs to be replaced as well as the blower motor.
There are some cars that wont allow the blower motor to work until the engine temp/outside air temp reach a certain temp, but I doubt this applies to your car.
What year is your V70?
Old Oct 31, 2007 | 10:11 PM
Volvocars's Avatar
Your T-stat is most likey stuck open, however it could be related to your ECT, located directly below your T-stat/upper radiator hose.
Old Oct 31, 2007 | 10:16 PM
bansaw's Avatar
the year is 1999 non turbo
could it be that its a Florida car now in Canada? I was going to flush rad this weekend, guess put new Tstat in.
if its stuck open, how could i tell and if possible how could i close it. any help is greatly appreciated. ty for your replies
Old Oct 31, 2007 | 11:10 PM
Volvocars's Avatar
No florida/canada make no difference.
If its stuck open it needs to be replaced. You can remove the T-stat cover -located at the engine end of the top coolant hose- and if the you know the motor is cold then the T-stat should be closed. However the T-stat may not have this symptom and still be the problem. They cost about $20; if I wasgonna do the work I'd put one in.
Old Nov 2, 2007 | 11:10 AM
bansaw's Avatar
okay i replaced the thermostat and flushed rad. water temp reading is back, you were correct - stuck open
so i reinstalled my blower to see and it fired up, ran for a few seconds then went off. heard a couple clicks later.
so i went to the local batteryguy and determined the alternator is going, belt is to its extreme as well.
you think thats my problem, blower pulling too much and it shuts off? its gotta be my alternator and belt.
thanks for your help, I appreciate it. any pics of an alternator swap?
Old Nov 2, 2007 | 06:28 PM
1996850turbo's Avatar
If the voltage is getting low due to bad alternator then current would go up. I am not sure how the blower is protected as far as current is concerned? Anyone know if it is a breaker or something that resets?
Old Nov 2, 2007 | 07:03 PM
I would say the blower is bad as well.
The control module cuts the blower motor if to many amps is pulled from the motor.
Old Nov 5, 2007 | 10:21 AM
bansaw's Avatar
okay so changed thermostat, water temp readinggood
changed blower motor. it runs fine so it was the blower.
now I have a C.E.L on, just a few minutes ago...wtf is going on? is this just one of those "when it rains it pours" moments?
robert213
May 30, 2006 03:23 PM
cameron
Feb 8, 2006 06:06 AM
Eric
Jan 11, 2006 11:43 PM
Buck
Aug 23, 2005 09:20 AM
jcmartin
Mar 1, 2005 01:46 PM
