Timing belt
Old Nov 3, 2011 | 12:52 PM
Iloaders's Avatar
Default Timing belt
Is it recommended to replace oil pump or water pump when replacing a timing belt on a 2001 v70 wagon with over 100,000 miles
Old Nov 3, 2011 | 03:15 PM
I'm pretty sure the oil pump is not. I would not recommend doing a water pump unless it's leaking.
Old Nov 4, 2011 | 09:31 AM
Iloaders's Avatar
Are there any other recommendation while they are replacing the belt?
Old Nov 4, 2011 | 09:40 AM
I'm not sure but you can contact the dealer or a Volvo indi shop and they will tell you what they recommend you do. On the pre '99 cars most people replace the idler, tensioner roller and tensioner but I believe the post '98 cars have a different tensioner that is not hydrolic so I'm not really sure what they do with those. Check FCP or IPD's websites and see what they sell as kits. I usually recommend that people replace everything, every other belt change or every 10 years. So, if the parts are 10 years old I suggest they be changed, except the water pump. If you service your coolant system properly that water pump will likely go 250,000.
Old Nov 4, 2011 | 09:45 AM
Here is the kit on iPd's website: Timing Belt Kit with Tensioner and Idler Bearing
Most people just decide to do the water pump because it's in the path and what is $50 when you're saving $250 on the job? That way they fill good about it being new and not having to go in there 2 years later for a pump and doing the job all over again. I had a belt done on my 960 and had to go back 28,000 miles later for the water pump and idler pulley.
7zarc7
Mar 24, 2010 07:17 AM
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
